Changing the clutch cable
(In Topic #91541)
clutch cable is looking a bit worse for wear and its going to snap one of these days ..
so going to change it myself
car is a 89 1.8 gti
don't have any specific question but if you have any advice on changing the clutch cable would be most helpfull
i know about the mrk 1 rust on bulkhead problem but mine is clean as a whistle
so just genral advice please
bit scared because i attempted this on a clio and well.. lets just say it was french and very stupidly plastic and difficult
thanks people..
<a href="Image hosting, free photo sharing & video sharing at Photobucket"><img src="http://img.photobucket.com/albums/v122/paulchalt/myadvitar.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
the main thing i can recommend is to buy some cable ties and make sure you tie it so it is in a straight, unstressed loop therefore no kinks,
I say this because on mine the wrong clutch cable was fitted before and it bent, causing the plate connected to literally wear away as the cable was sawing into the metal!
hope this helps
thats kind of dampened my fears of it being a biatch..
shall go see mr GSF shortly for a new one!
thanks
hardest part i find is getting under the dash to connect the plastic bit on the pedal!!! there just no room and its blooming hard to see!!!
Topoftherange said
its about a 1/2 hour job!! just make sure you dont lose the 3 pieces that hold the nipple bit at the g/box end of the cable!! you have to lift the clutch release arm to take the slack to release the cable, the metal piece has a slot cut into it,
Mine snapped a few weeks back, i got the misses under the dash to un-clip and clip it i just couldn't get to it plus she likes to help. So Paul if my misses can do it im sure you wont have any trouble
thanks people much appreciated!
Does your wife have a single sister?
<a href="signature2.jpg picture by jools182 - Photobucket"><img src="http://i88.photobucket.com/albums/k182/jools182/signature2.jpg" border="0" alt="Photobucket"></a>
any ideas, as i can see under the pedals i'm wondering if i was supposed you attach the cable round something else first before connecting it.
all fun of learning.
Current Babies
2007 Octavia vRS TDi 170BHP, Race Blue.
1983 VW Mk1 1.8 GTi Lhasa Green
1985 MK3 Ford Capri 2.0 Pinto
Previous Vage Babies
2004 VW Bora 1.4
Ex 2002 Audi 100 Bhp TDI
Ex 2002 VW Golf 100 Bhp TDI
Ex 2003 VW Golf 150 Bhp TDI
Ex 2005
2004 VW Bora 1.4
Ex 2005
MK1-GTi-Cork said
I changed mine yesterday as boy its hard on your own. I finally got it fitted but now my problem is that the clutch seems to have a lot of slack on it. the bag said it was defo for the MK1 Golf but i am now wondering.it have the adjuster out to the last as u still have to push it in fully. very little responce until you hit the floor.
i'm having this exact problem now… did you ever figure it out? it seems so simple but i'm really puzzled about it
i'm not daft mechanically, but this has me stumped. there's nothing left to adjust!
the cable is longer in the replacement that the original by about 4 inch. lol
I'm having the same trouble. I have fitted a brand new VW clutch cable and had to adjust it right up so its on the maximum limit just to take up all the slack in cable.
When I push my clutch pedal down it has a lot of slack to take up before it actually bites and starts to lift the clutch arm. I now only have a very small amount of movement between the pedal flat to the floor and the biting point.
I have previously repaired the bulkhead with a bulkhead repair plate, which I stuck on with chemical metal.
Please can someone help, I don't know why this is happening and I need a solution.
Thanks Chris
It's the wrong clutch cable. if you check it against the old one you will find that it's about 4 inch too long.
There are 2 different clutch cable part numbers and you need the shorter one of the 2.
That's all it is and i can assure you it's that after 3 nights of wondering what the hell was going on.
So i thought, back to basics - check it against the old one. It'll be longer.
don't worry about your bulkhead repair either. you can't have done that wrong.
I still have no idea what's going on.
My clutch release arm sits at around the 7 o'clock position when the cable is not attached. It becomes stiff around 9 o'clock and cannot be lifted by hand. It can only be lifted when the cable is attached and the pedal is depressed.
According to brokevw this all seems ok, doesn't it?
at the moment i know what your feeling. You've exactly the same situation as i had. but… i found the cable i had was longer that the old one.
are you sure it's no longer?
