Can I get disks with a 4x130 to fit a mk1? and can i fit beetle drums to the rear?
(In Topic #154174)
PLEASE HELP
You could get a set of golf drums re drilled at a decent machine shop.
Your problem will be with the front discs, or rather hubs, as it is these that are drilled out for wheel bolts.
Adapters would be the safest method if available, I have 20mm hubcentric dapters on the rear of mine, which are bolted up solid to the drums, been fine for the last 2 years
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
Proving centre bore is same, if not it would be ideal to make that the same too so your safe.
I would get the hubs redrilled.
If you look at your wheels, you will see that the area below the bolt holes is shaped during the pressing process to seat the bolts, it aint just a hole dude.
Also, have you enough clearance for brakes and suspension, if not you may need spacers anyhow!
What is the centre bore on the beetle wheels? Golf is around 57mm, this needs to be the same on the bug wheels.
Job done right, each time you want to fit new brakes you need them doing each and every time!
Go to a machinist and explain your requirements,they will fill the whole centre, get the surface flat and true then redrill to 4x100 with a 57.1 centre bore. Job done.
Brad. said
Ignore him ^^^
Offensive post dude….
just saying, may still have issues with offset once drilled, so spacers might not work out that expensive!
Up to you guys.
Maybe you could recomend somewhere to do the work?
I'd personally take them to g23 engineering as I've seen there work and it compares to no other. And you'll have the job done right in the first place by somebody that knows the Vw scene.
Its easier (and safer) to fit bling hubcaps to a wheel rather than fit a car to the wheels.
Driver driver.
