Caliper Sticking????
(In Topic #128959)
I now have a noise coming from my passenger front wheel.
It happens when I driving straight or turning.
Seems to be matched to the spinning of the wheel.
Sound like a grinding or scaping rather than a knock.
I think it could be one of three fromstudying past forum topics.
Caliper sticking or Wheel bearing or Cv joint
Please Help.
Ive jacked her up and checked both wheels for play. the passenger side does rock only ever so slightly and the driver side is solid. this is with one hand on the top and the other on the bottom of the wheel to show direction of movemet.
Ive also looked in at the cv joint by removing the rubber boot. truth is i don't really know what im looking for. all bearing were there…. and ive removed the brake disc and grinded the corrosion from the edge in case this was rubbing on the pads.
also its got all new suspension and top mounts. 4 x new matching yoko tyres. and the wheel nuts are tight for sure.
It stills makes the dreaded noise.
please help me out I want to keep my car in good shape.
rob
www.keets-customs.co.uk
COTM Team
also ive had the wheel spinning while the car is up and the noise can not be recreated….
if it helps it used to only make the noise when parking or turning around when the wheels were turned to the right. this would make me beleve its the cv joint but most say it sounds like a klip klop kind of sound rather than a grinding….
COTM Team
