brakes applying themselves after 16v servo conversion
(In Topic #105965)
more likely to be as paul suggested tho worth jacking up and checking each wheel :wink:
rpatten said
can't be i didnt put any on from the mk1 and the 1's on the S3 engine i never touched, theyre under the inlet mainifold unmolested. ??????????
The car's been off the road a significant time, things can seize up etc so you need to check everything, not just assume its okay beacuse it worked before.
rpatten said
how could a rear wheel bearing make the front brakes apply themselves???
Ok so if its front brakes binding, the rear wheel bearings have no, ummm, bearing.
Have you physically checked that the servo pushrod is returning to its at rest position consistently? Left or right or both front wheels? and no binding in the rears at all? Have you kept the diagonal split when plumbing in the brake lines to the servo?
The vacume hose thing could that slowly with the engine running at high rpm apply the brakes?
It's wird because when your bleeding the brackes if something was sticking you'd of thought you would of noticed it then but nothing and like i say it drives great and the brakes seem fine but then you notice the car doesnt want to coast freely, you drive a little further, just normal driving and the bineding gets worse until your down to 1st gear and the engine wants to stall.
don't get it?
cars are like women stubbon money grabing head aches
