Brake Problem on 1.8 karmann gti
(In Topic #86073)
Re: Brake Problem on 1.8 karmann gti
gropsy13 said
if anyone has any advice it would be awsome cheers.
Don't drive the car!
Welcome to the site. Sorry I can't help but someone else will give you a few ideas.
Danny
Mk1 GTi White Cab '86
Mk4 TDi
Mk4 TDi
Brakes are important : )
if you have little knowledge and some tools then grab a haynes manual and about 5 litres of brake fluid to thouroughly flush the system, if you are not comfortable with doing it yourself then dont take it back to the garage that carried out the MOT, find another!
tipremove and clean the inside of the master cylinder reservoir because if this is not clean then the system will never be clean)
hope this helps
ian t
Do it once and do it right! ok, we've identified the problem, lets not make it worse by guessing……… Identifying the sympton is not the same as understanding the cause
I really wouldn't drive it until you get it sorted. If it is the servo it is a great time to upgrade to the 16v servo and m/c. Add a pair of vauxhall calipers and 16v 256mm discs and you will have the best setup you can get for peanuts.
Have a look in the braking faq for more info on the upgrades.
HTH
The brake pedal is very soft and spongey. It doesn't go all the way to the floor but close. I have blead the brakes untill no air is coming out.
Calipars are in good condition, only thing I can think of is one of the cylinders in the back, the bleeder is broken.
Ny help appreciated?
aberry said
I have a problem with mine too.
Have you made sure that the rear bias valve is fully open when you have bled the brakes? This can trap air in if not (bleed them with car on the ground)
