Brake pressure valves and brake compensator
(In Topic #92757)
Does the rear one only work when there is extra weight in the rear of the car? Or is it always regulating the rear brake pressure? but it cuts off the pressure more when extra weight is in the rear and the car is under hard breaking?
I think myself, the rear regulator is always regulating the pressure to the rear and cuts off the pressure when there is more weight in the back so the other two valves are probably not needed??
anyone any insight?!
The 2 front ones are check valves , used to keep residual pressure to the rear brake cylinders . You need these unless you decide to change to disks at the rear .
You are correct ! It prevents the car skidding during hard braking .
Cheers…………..
