brake pipes
(In Topic #136822)
brake pipes
is the brake pipe set up any diff from the mk1 to the mk2?? and if so does any1 have a diagram of the mk2 setup?
also can i put mk2 hubs onto my mk1 or do i need to buy brackets to fit the g60`s onto my mk1 hubs…..
as always all help will b eh,,, helpfull, cheeers mick..
The second part of your question is already covered here:
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&p=705774&highlight=#705774
for the 2nd part—tushay lol. i thought i would ask the q again cos i have been asking and hunting on the web for the front setup and im sure that i read that u could use the mk2 hubs on the mk1 with a small mod to the hub but then u said diff and then i spoke to a guy who said u could so i dont know what the story is, i was hoping if some1 has done it they could let me in on the secret and tell me how to do it, im like molder on the x-files————the truth is out there, its just who is got the correct info……………
Fair enough, I guess I could tell you do to a search, but I know doing this brings up a lot of vague stuff you need to sieve through. Hopefully someone else can back me up and explain clearly why mk2 hubs don't work - while the bits can all be connected (not too sure about track rod ends though), the geometry is different/wrong, which makes a particular aspect of the handling unsafe. I'm not 100% but I think its the bump steer.
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=105840&start=0&postdays=0&postorder=asc&highlight=
