Brake pedal woes...Is this a VAG problem?
(In Topic #73886)
http://www.vwwatercooled.org.au/vwforum/viewtopic.php?t=12&sid=f4e5cfec5e61501ef5eb217e8f4916ce
and
http://www.vwwatercooled.org.au/vwforum/viewtopic.php?t=41
Strange thing is that the pedal is fine until you start the engine….
(Sorry, moderators if you think this is a digression from MK1s. You can delete the post if you feel you have to.)
Cheers from Australia. Peter.
1978 Golf diesel (GLD)
1984 Nissan Patrol diesel
1982 Peugeot 505 turbo diesel
As for bleeding the brakes on a Mk1, you just have to make sure the beam isn't hanging down when doing it (eg, jack it on both sides under the shock absorber mounts or jack it up and lower the car onto axle stands under the mounts).
Thanks, Mate.
