Brake Failure !!
(In Topic #89099)
Brake Failure !!
Went for a drive and the pedal just hit the floor with minimal braking and pulling to one side!!
I checked the reservoir and it was empty - no visible signs of leaks around the car. Not done a full check over but I'm thinking master cylinder failure.
First time I've had such bad brake failure on a MK1 (well any car for that matter!)
Any thoughts?
Rich
Web Team
White cabriolet Gti 16 valve
Cero said
I've seen occasions where the master cylinder has failed and the fluid has ended up inside the servo !! That might explain why no obvious signs of leaky pipes etc
ditto
That was after taking off the master cylinder of course and refitting it!!!
?10 later and it was fixed
Rich
