Brake disc screw sheared off
(In Topic #100667)
1988 1.8 carb Golf Clipper
The easiest way to do this is to fit the disc, bolt it onto the hub using the wheel bolts and then drill through in one go this way you ensure everything is lined up just peachy.
Good advice with the sharp drill and cutting fluid as well. I use cobalt tipped drills for things like this, seem to make life a little easier.
