Brake compensator/regulator
(In Topic #78593)
Anybody any ideas??
Cussco
?70.00 :dontknow:
There is no servicable bits in the compensator , i have stripped one to clean and check it but then had to replace it ops: as it gave to much pedal travel . Brake related parts are always better replaced if faulty on safety grounds . Good luck with it .
Chudd………
Up and running again
Anyway replaced compensator and some brake lines, as I had to cut one off after struggling with the getting OLD conectors un-screwed, put back together then found fuel leak from supply line. Must of disturbed it when replaceing brake line near fuel pump (looking closer at the rest, this will need replacing soon). Repaired with 8mm rubber fuel line (12 bar rated) and 6 jubilee clips, all is ok for now. My golf has really been testing my patience lately seems I fix one thing then another problem occurs. Still eventually I will have replaced everthing sorted.
One thing the lever and spring on compensator do not appear to be of much use as its never under tension with suspension up or down.
Cheers Cussco
Cussco
