Brake compensator valve
(In Topic #121013)
So…. Do I need a compensator valve for the rear brakes? I'm running MK3 Drums and a Corrado set up at the front. MK2 GTi servo with a passat 4 branch cylinder
I was hoping to get rid of it to be honest and if I need to use some in line bias adjusters.
Also do I need the regulators in the pipework near the master cylinder?
If you fit a full inline bias valve and actually do adjust it then you will be fine though as at least you can compensate for the difference between front and rear braking to what it would have been as standard. what regulators by the master cylinder? have you got pics?
on my cabby i made a bracket which allowed me to bolt on a MK2 Golf pressure regulator
rubjonny said
later cabby & rocco have inline reducers that will do the trick
So use the inline reducers instead of the compensator valve? I'm confused now?!?!
foxy
cheers foxy
ta
not eched
no screen
do you need rubbers?
how much ya want?
could u make sure it is VW stuff as well, Ta
This is why the later cab/rocco have the restrictors and no bias valve. Even the sciroco 16v with rear discs has restrictors and not a valve
Though the 16v ones are a different part number to the rear drum restrictors.
rubjonny: so how do the restrictors know there is wait over the rear axle? Still cant get my head round this!! Sorry!!
o/s drop glass
o/s front 1/4
screen
any good let m know thnx
Cheers and very sorry for sounding thick
