Brake Bleeding problems
(In Topic #101473)
I am having problems bleeding the brakes. There is not enough pressure and only some drips are coming out of the bleed valve.
Do you think its because of trapped air/dirt in front pipes? I have just put new brake hoses and brake pipes at the rear.
Car had been left and garaged for a long time.
Master cylinder issue? Would i need to replace that?
Yannick
Re: Brake Bleeding problems
Yan46 said
Hi all,
Yannick
Front or rears? How are you bleeding them?
rear
We can't seem to find any pressure going through the pipes.
Its like there is something blocked.
My dad is a qualified mechanic and finds it weird. He is suspecting that the master cylinder should be changed.
Thought I might ask anyone here who might have had similar or experienced similar problems
Re: rear
Yan46 said
its the rear, im pumping the brake pedals while my dad is adjusting the bleed valve.
Disconnect the rear compensator and set the lever (sorry can never remember which way), so that the compensator restricts as little as possible, then retry. Mark the position of the bolt, etc before so you can easily reset it. If its still blocked, then look for kinked pipes, etc.
pressure
