Boge turbo's/60mm springs
(In Topic #114266)
Hi Guys, looking for a bit of advice. I recently renewed all four corners of my '91 sportline cab with Boge Turbo dampers and just used the standard springs. I picked up a set of 60mm lowering springs the other day but I'm now wondering if 60mm will be too much of a drop for the dampers? Really looking for a subtle drop, so not sure if the 60's will be too much, maybe I should look out for 40mm springs instead? :dontknow:
Any advice greatly appreciated.
60mm is a fair drop, i dont have any mk1 pics to hand but heres a before & after pic of my mk2 on 40mm springs if thats any help:
Cheers mate, I think 60mm is probably going to be too much.
Something tells me dropping over 40mm on the Boges will affect the dampening, can anyone shed any light? Just looking for a slight drop with a nice sporty ride.
Yes, you need to match the dampers to the spring height. Some dampers are designed to accept a range of heights, for specific info on this the damper manufacturer is probably the best place to get the needed info from.
