Bad vibrations!
(In Topic #76745)
Bad vibrations!
Something is knockning and vibrating at the back of my golf (1983 gti) at low revs especially when i pull away in 1st. At first i thought it might be the exhaust knockning on the rear panel, but on closer inspection its not looking like it is. Perhaps dodgey wheel bearings or shock absorbers?? Any ideas anyone??
I'm now mk1less, ahhhhhhh!
Gone but not forgotten;
'83 Schwarze black GTi
'83 Lhasa green GTi
'80 Indiana Red Met. GLS
'83 Lhasa green GTi
Try rocking the car forward and back with handbrake on while person with best ears listens for noises.
Jack up the rear with the car in gear, front wheels immobilised with chocks and handbrake off and see how easily the rear wheels spin.
To test for rear bearings being shot, see if you can rock each rear wheel - i.e. grab left and right sides, or top and botton, and see if the wheel is loose on the axle. If you feel it rocking a little - new bearings are cheap as chips.
And the Golf+ website has a guide to replacing them
Check also that rear wheel nuts are tight :roll: and that the rear torsion bar bolts aren't loose - although if all the above hasn't turned anything up you might want to find a friendly garage.
AliCabrio
PS - you might also try to reproduce the noise with someone standing outside the car, or leaning out of a window (not on the queen's highway m'lud - they might be better able to pinpoint where the noise is coming from for you.
Mars Red 1.8 GTi Cabrio 1985
Seat Covers
Scratches
Leaky roof
1 million smiles per hour
Seat Covers
Scratches
Leaky roof
