Axle nut......help
(In Topic #107274)
Axle nut......help
I have a Mk1 clipper that failed its MOT due to a split cv boot and obviously I need to replace it, I have tried to remove the axle nut to get the driveshaft out however it wont shift.
I have tried Brute force, long handled breaker bar (which broke) Impact driver, Impact wrench and heat none of it seems to have worked, any suggestions on how to get the thing off, I don't really want to have to use one of those CV boots that comes in 2 halves.
Thanks for reading.
Life Member
happyboy said
i found a 3 foot ally scaffold pole on the end of my breaker bar does the job well
3ft, ffs i am lazy, mine is 6ft, no effort atall
cv joint
i need the procedure for replacing the boot, i have a replacement from GSF.
i have the haynes manual but cannot find the method for replacement. what do i need to remove after the axel nut to be able to remove the split boot?
thanks guys
kiley
