ats classics
(In Topic #110474)
ats classics
is it the actual rim that won't go over the caliper, or can you get the wheel on but hear them catching the caliper when they go round?
the reason i ask is that i run ats classics 13x7's and when i first got them, they had balancing weights stuck on the inside that were catching on the calipers.
once removed, they went on fine. just gotta find the right spot to put the weights on.
hope that helps…
ash
just remembered i've got gti calipers on mine, maybe they are slightly smaller than those on your 1.1?
just a thought.
hope the spacers work for ya.
ash
errr, i think??? it was a long time ago, pretty sure i didn't have to change the hub or owt.
you'd probably need the carriers too.
hope that helps.
ash x
