Ats classics spacer size
Hi got some ats classics 7j x 13 brake calipers are stoping them from sitting flush just wondering what the best size spacers to use are thanks rick
I've got standard small brakes on mine and I just had to slightly grind the caliper for my ats classics to fit if not tho a 7mm spacer shud be enough to clear it also I have  gti arch spats and on the fronts my wheel lip is flush  withthe  arch
mine are only just rubbing so have bought 3mm ones... not tried them yet though.
Thanks I'm thinking of just runing 10mm would I have to have 10mm on the back to look right thanks
25/30 mm beccause rear  wheels tuck in arch MOre than fronts
Cheers mate I will get on and order them
Wheels are on and 3mm was enough… bit of poke out the front and I reckon just enough on the back..
"blans" did you run spacers on the back. Also what size tyres do you have on your classics ?
3mm spacers all round.. only had clearence issues on the front really. The wheels are 7j front and back and I'm running 185/55's
 :mrgreen:
