ANYONE HAVE A TIP FOR ANTI ROLL BAR BUSHES ?
(In Topic #135211)
just taken off the anti roll bar and all the mounts to refurb and the bushes was a b!tch to get off the antiroll bar i had to cut them off with the stanley . anyway ive painted up the bar and looks well but im thinking will the new bushes be as hard to get back on ?? fairy liquid???
should help
washing up liquid and a nut bolt and washer tighten the nut so the washer pulls the bush in place hay presto #edd china
markyptinting
ill try the washing up liquid bud but the front anti roll bar is just a solid bar and wont be able to get a nut and bolt to do anything
Use the liquid but put a small thin screw driver inside the bush this gives a gap so the rubber can't suck tight to the roll bar….they go on so easy otherwise you will really struggle
85 Karmann GTI Cabby Black Edition
81 GTI Tin Top (1.8t "The Tarmac Muncher" )
i will il give it ago an ill post up what i did
cheers for the advice guys what i did was put washing up liquid on the bar and in the bush then like lagger said a small screwdriver inbetween the bar and the bush to stop it sucking too !
hey presto all done !!!
