Any issues with lenso bsx et38?
Thinking of buying some Lenso bsx et38 just wanted to confirm if any one running these has any issues with rubbing on standard suspension. Tried a search but could not find anything.
whats the width of them? but no should be ok, et38 is factory offset. worst case soem spacers will help, even 10mm should be alright ive had et28 wheels on a mk1 no problem at all
Got these on my cab. Et 35. I'm running coilovers and had to space them out to stop them touching.
The only thing I'd mention is that the rims hit my front calipers so needed a 10mm spacer to stop that (I have standard gti calipers)
Recently rolled my arches to stop any scrubbing issues.
You may need to do a few mods to make them fit right but not too much trouble.
If you are anywhere near togear in bridport I'd recommend getting them from there. Speak to Justin who'll sort you out.
Sorted all the spacing issues for me whilst fitting.
Went for 16's on mine. Have a look at my thread for a bit more info.
Mk1 Gti Cabby project on the go! Detailed engine, roof off, leather interior, 16's, painted, now getting put back together!
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=103263&start=0&postdays=0&postorder=asc
with the fronts your cabby probably has the later caliper setup which has the big hoop on the carrier, this hits many types of alloy wheel. earlier cars dont have the hoop and so clearance is ok :)
Ideal!
That'll explain it!
 :D
Cheers for the info
