another top mount question ad also wishbone bushes
(In Topic #122136)
got my new febi top mounts today, already had one strut off so just popped in the garage and put one on and i have a slight rock side to side, is this right or is my new spacer to big?
problem is some muppet who had the car before me or who ever fitted the coilovers had bodged the whole job including using what looks to of been a haner and chisel to move the spring plates and also fitted the standard suspension spring cap on top of the coilover spring plate so just want to check whats right and whats not.
also wishbone bushes, will it make a diffrence to the handling if they are replaced for new ones?
thanks
nathan
Normal , play is taken up when the weight of the car in on the strut , if you leave out the spacer you wreck the top mount in a matter of days .
If you replace wishbones and suspension , you will feel a difference if the old bushes are worn .BUT you must get camber and tracking done on completion
ok thanks .
yeah i needed to get camber done anyway cause when i got the car the tires where like new on the outside but had the wires comming through on the inside! cant ever of been done when the coilovers where "badly" fitted in the first place.
so you wouldnt recomend filing down the bush slightly just to take out the free play?
thanks
nathan
the results are definitely worth the effort!
