Alloy Wheel restoration
(In Topic #73729)
Picked up my 13" BBS cross spokes at the weekend.
Nice enough, minimal kerbing, GOLD paint has stayed on 3, fallen off one leading to some corrosion.
Anyway, I am going to Nitromors the lot to get the paint off.
Then the rubbing starts. However cos they are cross spokes it's not gonna be easy to get in some of those corners!
I am wary of normal steel wire brushes because they will obviously scratch the surface.
Anyone tried brass brushes or steel with finer bristles?
Peter.
1980 1600 GTI, daily driver.
Steve_Matthews said
Might be easier just to give them to a blaster and save hours of niggley rubbing down…
And will leave you with fingers with skin left on the ends as well !!
Probs only work out to something like ?40 to do a set of four wheels.
I would seriously consider the blasting option… or possibly acid dipping/cleaning if you can find someone to do it…
My Build Thread
Peter
So, obviously I had to test it on a small patch, seems OK but it's a bit gnarly for my liking.
Picked up some polycell paint stripper which has a slower reaction time so I'll give that a blast later.
Used a steel wire brush to get off the worst of the old paint. Went really lightly to avoid scratching alloy. Gonna pick up some brass brushes and get really stuck in later.
Glad theres only one that needs complete stripping!!!!
Peter.
sandblasting would pitt the wheels, i have a sandblaster but use aluminium oxide abrasive to reduce this, its ok on wheels that are gonna be painted but if your polishing and you dont want to take off any metal from the wheels then your taking the correct route with the paint stripper…
how are you getting on?
