4 to 5 speed
(In Topic #73880)
4 to 5 speed
I've recently bought an x-reg Mk1 Cabrio. Fantastic car but one problem; it has a four-speed 'box and I'd like to fit a five. I've had a bit of advice on this but nothing conclusive.
As far as I understand it, it's not as straight forward as swapping it round. Any ideas?
I'm sure someone's done the 4 to 5 speed change before so you should get a fairly quick repsonse
cheers,
paul
Unfortunately, I've not actually had a definitive answer on this. When I do, I'll fill you all in.
As I said on a previous post, I work for Kelsey Publishing and we publish Car Mechanics magazine. I'll put this question to Peter Simpson the editor (one of those guys who knows pretty much everything) and see what he says. If not, I guess the answer is simply to give it a go and see how it works out.
Anyone know what box is required to upgrade an 1100 to 5 speed? I am pretty sure from memory that the GTI box doesnt fit as the bellhousings are different.
Again from memory (been a while since I had a mk1, and suddenly find myself with 2 ) I think a Mk4 Polo/Lupo gearbox fits..
anyone shed any lights :dontknow:
Mark
My cars -
72 Moonraker - http://www.volkszone.c…i/showthread.php?t=304603
MYSPACE
My cars -
http://dubforce.net/pi…files/webfiles/Rallye.htm72 Moonraker - http://www.volkszone.c…i/showthread.php?t=304603
MYSPACE
Cheers 8)
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
Right,changing the box is easy,i put a 1997 box into an 83,i changed the linkages under the bonnet,still felt wrong,no 5th gear,the actual selector in the car is different,and the shape of the rod that runs up the car is different,to fix it temporary till tomo320 (parts store) brings me the 5 speed selector i got the angle grinder and give myself more movement be grinding the moving part under the car bt 5mm
Tops,now got 5 speed 8)
Cheers Bert
