280 mm g60 brakes 1.3 mk1
(In Topic #112702)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=280357700733
braemarboy said
aye i found a master cylinder , just having trouble findin a servo
servo - any mk2 from the scrappy should be a 9" diameter one, it doesnt have to be a gti one iirc, and esp not a 16v one.
on the master cylinder if you have a second hand one make sure you have the reservoir that holds the fluid and check the seals very carefully where the reservoir pushes in…I got a cheap master cylinder and servo as a pair, fitted and it was never right then one of the seals holding the resivior gave up and started to leak fluid at a rapid rate if it was moved - luckly I noticed this on the drive - so rather than replace the seals I just got a brand spanking new mc with seals included from GSF for ?34 and then cleaned the reservoir out by filling with brake cleaner when off the car, shaking around alot and then emptying, and repeating untill clean.
this made the brakes even better as the old MC was a little bit past its best tbh, so worth keeping in mind…it maybe worth spending an extra ?30 on a new mc.
All 1.8 carb, GTI & 16v all got the bigger 9"servo though, and I believe all automatic and diesel models got the 9" servo too.
