280 mm brake upgrade , right ones ???
(In Topic #143605)
i bought the conversion brackets on ebay for the front 280mm upgrade,
went to the scrappy earlier and luckily found a mk3 golf 16v with 280 discs, i got all the necessary bits, the only doubt i have is that the discs had 5 studs. i thought it would be ok.
does that make any difference when i get 4 stud 280mm discs ???????? will it all fit togeather ?
yes / no ???
thanks
im aware i need 4 studed discs thats kinda obvious but will the 5 studed brake caliper / carrier setup work with the new 4 studed g60 discs im gunna be getting ?
I just wanted to know if I had to source my brake setup from a vw with 4 studs
The calipers are 54 Lucas I've read in some forums that this is correct .
Thanks for your reply
Result
close ha looks sweet !!
with a little filing on the hub, allows the adapter bracket to fit sweet.
massive size difference
