1983 Golf GL. 1.5L carb'd with 5 spd. what size clutch &
(In Topic #99942)
i need to know the size of the clutch and pressure plate.. is it 190, 200, or 210 mm??
this is a german imported vehicle, we didn't have them with this spec here in the USA so it's hard for me to tell some things, and i don't want to drop the trans to measure it and be down for the count.
if i can't figure it out i may just upgrade everything to the 210mm and put in a 210mm lightened and balanced flywheel, but i'd rather use the stock size and re-use the flywheel.
any help would be great. thanks
Pretty sure for petrols:
190mm
All 1.5, 1.6 carb engines
200mm
1.6 GTI
210mm
1.8 GTI
diesels, and later 1.8 cabbies, are a bit different.
190mm
200mm
1.6 GTI
210mm
1.8 GTI
ok thank you.. i was thinking it was 190mm as well because most of the parts are the same as a 1984 1.7L gas jetta that we had here stateside.
i'm hoping i can re-use my flywheel since i don't really want to rack up the extra cost of a brand new one i don't really need
