16v master cylinder size?
quick question for you guys on here.
how do you tell a 22mm m/c from a non 22mm and what part of it is 22mm?
also what other m/c fit on a 16v servo anything bigger that 22mm?
i ask as i have just put G60 front brakes 16v rear brakes all running black diamond discs with goodridge braided hoses all round and have discovered the m/c is in need of changing.
any advice is very welcome
thanks
83 mk1 GTI
bought a house so need to start hiding what i buy from the wife
The 22mm is the bore size, think there are bigger ones but cannot be more specific, but too large is not good.
can you tell me why?
is there a way i can mesure the bore size or is it internal to the unit
83 mk1 GTI
Dont have a cylinder to hand but i think you can measure from the back of one , where its assembled. too large a cylinder and you just cannot press it hard enough although you would have very little movement.
ok thanks for that.
does anybody know what one from euro car parts i need? as there are about 4 to choose from or do i just get the one with the KR engine code.
sorry for all the questions guys but i know nothing about MK2's braking system
83 mk1 GTI
Usually the bore size is stamped or cast into the outside of the cylinder.  So long as you select one from ECP that is for a 16v post 1989 they're all the same bore just different makes, make sure it's 1989 or later though as the earlier ones had the smaller 20mm master cylinder.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
excellent thanks for the info guys
83 mk1 GTI
The T4 transporter has a 23.81mm master cylinder that  you can use on a 16v servo
do you have a part number for euro parts
83 mk1 GTI
132545030 should be ok. Bendix m/c for a mk2 G60.
'81 1.8T
BMW R1200GSA
Caddy 2k 1.8T
