16v brakes
(In Topic #106457)
16v brakes
Is it a case of taking the hubs and brake setup from the jetta and putting on the Mk1 or is it more complicated??
Obviously I'm going to be using the servo and m/c from the jetta too :wink:
TIA
Presumably if I wanted to convert to rear discs I can just swap the stub axles etc from the jetta too? and if I've read write use scirocco handbrake cables?
yeha said
Yes, the rears will go straight on with the 16v Scirocco cables. This is what I have. You will want to do something about the rear bias though.
Not really, you need to grind a small section of the axle away, somehow make solid-flexi brackets, make longer solid brake lines, and ideally tabs to hold the handbrake cable, etc too. It does fit but it doesn't go "straight on".
