020 Gearbox Help
(In Topic #91733)
020 Gearbox Help
Are the any other main differences in 020 gearbox's apart from the driveshaft flange thickness ? can you change the drive shaft flange ?
How can you tell what ratio's are in the box or are they all the same ?
What is the best gearbox ratio's if they are different and I imagine they are.
Good pickup is key as most driving is short and twisty :roll:. I do not do much long distance work with it but it would be nice to cruise at 70 without killing it
Anyone got a spare box :mrgreen:
At least I have a digifant that ticks over
TIA
If its not broke....I will break it
020 GB
Fromm this I have found out my gb code is FD and is a close ratio box.
All I need to do now is find a suitable box. Its a bit hard to know what to do in respect of ratios as I have only driven the MK1 10 miles since owning it.
I'd go on availability rather than worry TOO much about ratios, so long as its a close ratio GTI box.
The flanges are interchangeable but obviously if you have the choice of 2 boxes, one with the right flanges and one with the wrong ones, it would make sense to buy the correct ones so you don't need the hassle of swapping them over.
