What wheels are 260mm Wilwood users running?
(In Topic #219962)
My G60 van build continues and wonder what ET & offset wheels fit the Wilwood 260mm.
I had 256 wilwood dynalite and inside of the caliper touched the center of the wheel so et didn't matter but shape of the wheel did. you can see a slight mark on the lower piston
I had g60 sebring wheels fitted but struggled to find anything else to fit without spacers so I would go for something with a high et and space them acordingly
actually has marks on both pistons
Any Idea if the 16" Up Classic wheels would fit?
not sure but look to have et of 43 so more likely to be able to use a spacer to increase the space on the inside, it looks quite tight on the inside of those wheels but hard to tell without measuring
Anyone else running 256mm wildwood?
I have 280 but same calipers it will depend on the style of wheel if your spoke sits out on the face you will be able to use et 35 upwards
Last edit: by vdoubleu
