Engine Identification
(In Topic #237511)
First of all, I know this top has been discussed but I have never been able to find an answer to my question.
Please find below a picture of an engine that is supposed to come from a golf mk1 S (1979). However, I haven't been able to find the engine code between plugs 3&4.
Is anyone able to recognise it? If more pictures are needed, please do not hesitate to ask!
Thank you in advance.
Last edit: by Swarlaw
The engine looks like a 1.8 EX engine, I could be wrong as it's not a UK car?
I guess it's not running at the moment as you are missing the breather hose from the rocker cover, the hot air feed to the end of the air intake and the sensors on the coolant flange are not connected?
Thanks a lot for your answer!mark1gls said
The engine code is just above the fuel pump, stamped on a flat surface on the engine block.
Indeed, it is not a UK Car, it is from the Netherlands from what I understood.
However, it is actually running. Should I check it before running it again? I have the temperature gauge (and working), and I've never suffered from a too hot engine.
Early-1800 said
Agree looks like a mid/late 1980s 1.6/1.8 with later sensors and wiring connectors, plastic clipped cambelt cover not bolted on metal cover, plastic dipstick etc etc
Thank you a lot for your answer
There should be a rubber hose from the rocker cover breather to the top of the carb.
There's a picture here.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=helllllpppp%2Funtitled_263
I guess someone has changed the carb from a Pierburg to a Webber? I believe the coolant sensors on the front of the engine tell the Pierburg auto choke when it's needed so if you have a manual choke they are not needed.
I don't have a 1.8 carburettor car so not 100% sure, just an 1978 1.6 Scirocco and that does not have those sensors on the front of the engine and I've also fitted a Webber.
The hot air feed on the air intake only works when the engine is cold to stop the carb from freezing up especially when the outside temperature drops, it won't make any difference in the warmer weather.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=big-block-carb-engines_2%2Fair-filter-housing
