The money pit build 2! Full ground up build.
great progress mate, are you trying to keep the scuttle area free from pots?mk1 daz said
Dashboard mucked in.
Cut air tubes away to allow pots to be mounted behind dash.
Coming on well - conversion looks factory perfect!
How will you fill the pots….?
Yeah, trying to keep everything out of the engine bay
There's more room than it looks but worse case 100mm syringe with a long rubber tube on.
A bit more work on braking system
A few updates
Regional Host NE
Looking good mate
Paint correction done, paint redone in places required to improve finish, clear coat and added plus polished.
Hi great build, I'm also in process of fitting pedal box. My only comment is that I though .625 for front and 0.7 cylinder for rear, just what I've found on the forum? Hopefully you can put me right as you have 0.7 to front looking at the photos? Stand to be corrected?
