Restoration with a twist
(In Topic #181772)
Want to change lots of things
Brakes so they are much better got told(servo & master cylinder) which ones fit????
Power steering rack which one fits??????
Want to get gearbox refurbed but don't know where????
Rear brake conversion to discs mk2 fit?????
Respray original colour!!!!
I have done lots of things to this already so if u can shed any light on situation would be great thanks for your time, also I'm from sussex area so any local specialists that could help would be great!
Brakes - I'm out of touch on that one but 16v MK2 used to be a popular replacement
Power steering - no idea to be honest - a lot of work I would have thought - do you really want to do that?
Gearbox - I got quoted a price for my MK2 16v box from these guys - http://www.volks-apart.com/ - they seemed competitive
Rear brake - yes they do - I think MK3 also, both with new hubs. Personally I wouldn't bother unless you're putting a big power engine under the hood. Most of the braking is done by the front wheels and if all is set up well rear drums would be spot on I think
Respray - you need to find someone local that you can trust!!!
Hope that helps
I'm new at the forum, but I have the same project (though a cabriolet) and I'm also looking for simple improvements. I what to upgrade the brakes motor (i'm going to put in a bigger one in) and anything worthwhile to do if it's a simple operation and parts second hand are available, so please keep me updated in your project. I have installed a mohair top, painted it metallic grey and put in a leather and alcantara interior uptil now, but I want something faster and a bit more economical. I'm thinking about a 2.0 seat or Vw motor with a multipoint injection that makes it faster but not a gaz guzler…make it a wolf with a a sheep skin..
federico
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
I love it. I don't care what you think
Design Manager
Get some pics up!T28 said
Hello starting a mk1 cabby just need to try and pick a few brains and ideas off people if you can help will be much appreciated. Got a late mk1 1991 cabriolet and want to change lots of things so here's the list;
Mk2 Servo and MC or Bias pedal box and remote servo depending on what you want to spend and your future plans.T28 said
There are a couple of options Google is your friend, Toyota Starlet hydraulic system will fit with some modification or simpler than that a Corsa C electric power steering system will work again Google.T28 said
There are loads of places that will do this for you, the gearbox isn't rocket science so somewhere with a good rep will sort it for you I'm sure, try recommendations from above.T28 said
Not worth it unless you make the brake bias adjustable front to rear, I know discs look better but again as others have said before be careful as if you brake hard you will end up sideways. Bias pedal box is best or a pressure regulator for the rears.T28 said
Hope that helps,
Joe
2018 Up! GTi 1.0 TSI
2015 Mk7 Golf R 2.0 TSI 4motion DSG
2011 Caddy Maxi Kombi 1.6 TDi
1982 Mk1 Golf GTi 3 Door 1.8t - Build Thread
