Ollies 20V Black GTI
(In Topic #238644)
The interior needs. But of attention but the long term plan with that is a full retrim.
First things first the Speedo isn’t working, so potentially needs a new cable. I’ve had a fiddle around with it but no joy..
The car came with a minor oil leak, sorted that on Sunday with a new cam cover gasket.
It has a noisy fuel pump, and the previous owner gave me a replacement with the car. The starter also might need replacing too.
But regardless of the little niggles, I drove the car home on Saturday afternoon through the Cotswolds smiling ear to ear all the way back. Still pinching myself that I’ve finally got myself a mk1.
Cheers everyone,
Ollie
I think some of the GTi strips down the sides will finish it off lovely.
thanks Mark, and oh yes really stretched it's legs for the first time yesterday, heaps of fun! 😁mark1gls said
Looks good Guy94, I bet you were smiling with a 20v under the bonnet.
Great suggestion, thank you! I may rebadge the rear and just have a subtle 20V badge instead. First things first though, will probably be a shortened sump pan as this sits very low on this engine. And a quick release steering wheel for a bit of added security! And because the other is pretty worn out and generally not to my taste.
Ollie’s 20V Black GTI
The front is a bit more tricky. I have no factory rain tray as it’s been cut out - I have sourced one which will get welded in when it arrives. However the water ingress has only occurred since being parked up after a night of rain. There are two oval holes on the chassis leg exposed so I’ve temporarily plugged them with some duct tape as I fear water may be running down there. The engine loom grommet didn’t look to clever either so I have taped that up and will definitely be replacing that. Thirdly, I already knew the sill had been replaced on the passenger side, and now I’ve ripped back the carpet I have seen that there is quite a large issue…. Photos bellow. Will need to prioritise this, and get a professional opinion on the repair. Potentially the sill ought to be done again and some of the floor too.
So understandably I am a little down beat about the car today. But these are all things that can be solved with time & more money.
I have dried everything out in the car and left the carpet out to see if I can get a clearer path of where the water is coming from. If my temporary plugging efforts solve the problem then I will look to a more permanent solution. Pretty gutted about the sill/ floor situation though and just generally having to deal with water inside the car. I took the car out for a drive this afternoon just to remind myself why I bought it in the first place.
Porsche S2 turbo door handles now fitted and love the way they look. I’m not going to go too mad with shiny bits but I think a chrome filler cap would finish it off nicely.
I gave the car a full service a few weeks back, including new pickup pipe and the ECS tuning hybrid sump. I also changed the oil pump for a new one whilst I was in there.
I also have a new rocker cover painted in wrinkle black to fit, along with the Porsche filler cap. Will fit that when I check timing.
Current progress shots. A bit more still to do, including the door, as the bottom is starting to rot out.
Sadly this means my plan of cleaning up the engine bay over winter will not be going ahead, but I will sleep easier knowing the rust is being cut out and good metal being put in.
Onto the rotten door next
Website Manager
cheers Ade - a little sooner than I initially anticipated, glad to be getting it sorted thoughlhasadreams said
Looking great!
Great to see new metal going in.
Be well pleased if I can get the same results.
