New project
(In Topic #209279)
Sent from my KYOCERA-C6745 using Tapatalk
New project
This yrs winter summer project. Once my cabby finished
Sent from my iPad using Tapatalk
Chairman
New project
Looks like you'll have your work cut out for you!
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
Where did you find that - at the bottom of the sea? Well done rescuing another MK1 from the scrapper.
Yer was parked next to the titanic
But was cheap £520 eBay.
only joking rat look probably cheapest way out
nice
New project
Put jump pack today with drum diesel IT STARTED FIRST TURN SWEET AS NUT
shud see floor sills etc. Solid just pity about the top side
Chairman
New project
Glad it's at least running! Lick or paint and it'll be done in no time….
Follow us on:
Follow us on:
New project
Started sort out jobs try get water tight changed door and wing bonnet now
Was very shocked see how good iner wing and post was very solid.
New project
Cut out rotton B pillar cover fit new panel but needs repair behind panel. Weekend job
New project
Bits welded in patch on rear panel as well welded up hole in roof next job rear window out weld up back panel. Then same other side .
New project
Bit more done over weekend front window out new bottom panel from Vw heritage really bad fit but got there. Second hand Pillar and roof bit picked away and welded in.
New project
Went fit windscreen back in today try keep it dry and ðŸ~±. Dam Dam Dam I hate these windows when done my Cabrio 3 Windows later so now it's taped in.
Is there easy way fitting them with out cracking them
New project
Cut the seal with a sharp knife is my only method. Costs you £40 for a new deal though.
