Mk1 Tin top project
(In Topic #220906)
Purchased the car a few years ago with 52k on the clock , had thought of selling then after getting the car home from storage I decided to start tidying it up. A small repair around the tailgate I though and a polish soon turned into a full re spray and restore!
Trying to keep and restore as many of the original parts as possible, engine refresh / new clutch, water pump cam belt etc. new bilstein inserts suspension, poly bushed, caliper refurb.
Had a few headaches some difficulties in sourcing some parts ( new sunroof cables in particular) few more bits to do :
Last edit: by emhughes
Looking great, nearly there!
Wow that looks good and great attention to detail.
Good to see you are keeping it original.
Is that your garage as I wish mine was that big and tidy
awe-inspiring work!
Fausto said
awe-inspiring work!
Thanks Fausto, will be well worth the effort when I get it on the road ready for summer!
Stainless steel heat shield made and fitted
Now that's a heat shield, should keep the UJ boot in good condition.
WOW, What a Transformation
S/S Manifold heat wrap, had to cut 20mm off it and re weld to clear the rubber gaiter as I think it was for a LHD car.
New Bilstein inserts, top mount kit, hub bearings, bottom arm refurb polybushed
Rear axle cleaned and painted
New poly mounts
