Long Waiting G60 Project
(In Topic #200106)
The car is originally a 1981 1.6 GTI in black, the car has sat in the garage for the last 20 odd years since my dad bought it, stripped it and then it just got left. The car is solid as it hasn't seen rain since it was put away.
The car is pretty low mileage and I know people are going to say put it back to original but I have no proof of mileage, no original engine and I don't se myself ever selling it so I'm not too worried about it's resale value. Saying that I think I will only make changes that I can reverse just in case, so no real body modifications or anything.
It's currently got no engine and box in and the plan is for a G60 conversion with a stage 4 charger which I had rebuilt at John Mitchell Racing (who were very helpful!). Ive been collecting parts for what seems like years and I think I have everything I need.
I have got to confess that I don't really have the skill or tools to carry out this work on my own so I have found a mobile mechanic through a mate who is going to be giving me a hand so I can learn as I go, thought it was a better idea than just sending it off for someone to do it all.
A few more pictures:..
I'm not going to go crazy on this because over next winter I plan to replace this with a CTN box with a diff fitted.
I should probably say that this isn't going to be a show car, just a tidy, fun weekend toy
daniboy123 said
That connection goes back to the supercharger, it's the boost return. As you open the main throttle butterfly the boost return closes allowing the air to enter the engine. The engine doesn't need all that extra air at low revs and this allows it to be bypassed back to your supercharger. Hope that makes sense.Â
So that goes back to the outlet on the right hand side of the charger (when looking from the front of the car) which a lot of people blank off?
daniboy123 said
Yea  that's it. You can blank it off and put a filter on throttle body so long as you give the charger a spray with the correct lubricant once in a while.
Thanks, that's a great help!
Without the boost return the engine will be very loud as air wooshs out of the throttle body. I decided to make a custom joiner to the charger in order to retain the boost return and quieten everything down.
You can add a cap of oil to the charger with a blanked boost return but if you go the lubricant route ensure you get the right stuff from a g60 specialist as using the wrong stuff can do more harm than good.
Rich
RichG said
As per Dan, a lot of people blank the boost return side of the charger off as there is very little room in a mk1 with a g60 radiator.
Rich
Ok, cheers, I'll probably try without then if it is too loud have to think again
Gave the engine a service too with new cam belt, plugs, water pump and belt for the charger, a few pictures below although the quality is pretty bad as it was dark by then and only using a camera phone:
We would have got the box connected back up to the engine but when we opened the clutch box up GSF had given us a random flywheel rather than a vr6 clutch!
It's the mount for cable that is fouling and I need this as I'm not going hydraulic yet. Has anyone had this issue? What's the options? Is just a case of loosing the reverse switch from the tower?
I've been looking for an 02j cap but with no real luck, does anyone know if they are still available from vw? And if so what they are actually called?!
MPF85 i fitted a o2j tower as well but u dont need it really if u brought the polo shifter the end clips that clip too the tower come off so u dont need the o2j tower just swop them over from the g60 gear shifter if that makes sense
Be here now said
nice looking project iim in the process of doing a g60 mk1 as well so if u need any advice ill try an help
Thanks for the offer!
I managed to get the 02j tower fitted in the end. I bought the end cap from vw
The problem I'm having now is the polo cables don't fit on the tower! It looks like the pegs on the tower should go through the end of the cable but the cable ends on my shifter look like this
Can I just unscrew these and change them with ones that would work??
16vseries1 said
nice to see a solid car get reserected
thanks! I really need to update this soon, we have made a fair bit of headway, just waiting for some new hoses to arrive and it will be running! (hopefully)
