Here is my latest
(In Topic #199367)
Lifted the carpets and removed the sodden wet underlay. Fitted some wheels / tyres I happened to have, nothing special but the size (7 x 16) I wanted and the correct et. Temporary fitted a pattern grill without the spot lights, it will be fitted with the red trim / badges and staying. For some reason its now stopped turning over and hence wont start, not a problem as I intend to do an engine conversion anyway.
Have you found the water leak or was the underlay just wet from general sitting around?
What engine conversion are you going for? 20VT?
Last edit: by abfmk1
No its not an ABF, its an AUQ, 180 bhp and potentially 225 ish according to the qpeng website. So now it wont be running this year. What ever are all those pipes for?, hope I can lose most of them.
Only bit of that exhaust i would worry about getting TIG'd would be the flange, you dont want to warp it😉
You may need to trim more of the lower cambelt cover than you think too due to the chassis mount. Had to pull my engine again to trim a bit more when i first installed it, yours may be enough though, worth a check!
Getting your head around what pipework you dont need?
Yes you can take a look anytime! Now winters here (almost) am thinking about ripping the turbo out and putting the k03s in. Just got to figure out what to do about management. Was contemplating the mbe 992, its been reduced on tge qpeng website…. but not sure and waiting on an improvement on cash flow lol 😃
I'm going ABF on jenvey ITB's love the sound of normally aspirated and I'd say 200hp in a mk1 would be more than enough.
