Golf mk1 20vt bam
(In Topic #191799)
Have you looked at the justcaddys hydro kit? I've just fitted one although haven't got the car fully back together yet and I still need to add fluid and bleed. The fitting was pretty straightforward although you do have to remove your steering column and exchange for a modified one
There's a couple of pics in my build thread (link in footer) of getting the old column out. Must update with a few more pics as I've done a bit more on the car since last update
quicksilver said
Nice will have a look, will the box also delete the master cylinder on my bulkhead for the brakes? I wanna delete all that jazz.
No it's hydro clutch only. Retains the standard mk1 brake setup
Thanks! Definitely not rushing things, but a lot of that is not by choice. Don't get as much time in the garage as I'd like and this latest project - gearbox and hydro clutch - has thrown up various other niggles that I've wanted to take the opportunity to fix along the way. Hopefully back on the road within a fortnightquicksilver said
Just been thru your build thread, nice work!! Can see you taking your time and not rushing things.
if you need a hand with anything just give us a shout
Ty
