75 phoenixrot swallowtail project - with video!
(In Topic #197330)
It was pretty rough, and I spent a fair amount of time working in new inner and outer rockers on the driver's side, and getting the floorpan to cooperate with the inner sill again. The previous owner has just bent up a piece of sheet metal and screwed it to the sills to make a 'rocker panel', without closing off the end. If you live on a gravel road, that becomes a shovel. Guess they didn't think about that one.
I found a set of doors that were in perfect condition, just need a respray, since mine were rotted out. I've also scrounged up an AEB 20v 1.8t conversion, a 02A transmission with a quaife, and some tech-53 mounts to get it all hung in the car.
Scored a great deal on some Gotti 2-piece wheels, which seemed perfect for the car…
Found a set of audi 4k Quattro front calipers at the junkyard, and my old H&R coilovers are installed. I'm still in the collecting parts phase for this car, while my Datsun roadster project is at about mid-point. (the whole reason the rabbit isn't done, plus I needed a break from building rabbits)
In true rabbit fashion, they breed.
I found another 1975 phoenix red on craigslist about 2 hours away, and went to snatch it up, in the hopes of a 5.75 car being in better shape. I was really wrong. This one is rusted to the point of not worth saving, even the area above the tie rod portal on the passenger side is rotted through. Lots of good interior and exterior parts to make my time worth it, though. The rest of the parts I don't use will help other swallowtails live on. It looked good in pictures.
It's all pulled apart and waiting for me to get back to figuring out what to keep and get rid of.
I'll keep this updated as I snag more cool parts for my project, and hopefully get it on the road sooner than later.
Between the 2 projects, I'm good on shop work for at least a few years….
Last edit: by lagomorph
So to play a little catch-up, I had to part out a 2001 new beetle to get this quaife-equipped transmission, and got a really good deal on the AEB 1.8t engine from a junkyard that was closing. So it got hung in the car to get it out of the way, and off the shop floor.<br />
<br />
I also picked up a set of 2010 GTI heated seats with the plaid centers. They will be a great fit for the car, once I modify the floorpan to accept them, and restitch the rear seat to incorporate the plaid fabric.<br />
Started tearing apart the rusty 75 today, cutting apart the hatch (nearly rusted in two) and the rear taillight panel to make some wall art. Still going through the boxes of stuff in the car to figure out what I have. Looks to be a complete 1.5 carbed engine, in pieces, and the correct transmission with the side mount starter. The passenger side engine mount looks like a medieval torture device, it makes the diesel engine mounts look diminutive and simple.
I've also figured out a way to reinforce the body at the b-pillars to help prevent the cracking at the door/window junction on the early cars. ( I think). I've found a few suspect joints in the b-pillar interior that look like they allow rock-crawler type flexing. Further testing will commence on the junk shell before final determinations are made.
Packaged up a dash I put together out of spares to ship to Florida. I think I have most of a set of green tinted windows as well. Not to the bottom of the pile yet….
And I hope to get working on the crusty Datsun soon. Welding old Japanese metal makes you a better welder on anything thicker, like a soda can.
I'll post some sneak peeks in here every now and then.
Been working heavily on making a set of 2015 GTI seats fit into the car - much more work than I expected, but almost done with that - a few episodes behind in production, but ahead of schedule.
Link to the channel -
https://www.youtube.com/channel/UCuLMZ3UjAQ0fO3PBX4EblBQ
What are the rules in oregon as far as your engine swap emmisions etc?
I'm in Washington, just north of Oregon. Since this is titled as a classic car, I really don't have any restrictions on what I can do. Newer cars, we can swap engines, but you have to put a newer engine in the car, and all the emissions equipment on top of that. No question that the engine is newer than the car, so even if that were to come up, I'd be OK.
One of my previous cars was a mk4 jetta wagon that I swapped to TDI. Never had a problem, even with emissions testing, I told them it was a diesel and they tested it accordingly.
Thanks for watching!
https://www.youtube.com/watch?v=Dycf4_SJhrg
https://youtu.be/MxdNRoXCJDI
my pal Seth-
https://www.youtube.com/watch?v=LW6FMUQ7YDg
and his REALLY bad door hinge!
https://www.youtube.com/watch?v=iBRFgf1a9vc
Soon, we'll be doing a suspension install, and flex-testing the body bracing that I made to see if it really did help strengthen the unibody, or if it's just warm fuzzies!
Did a suspension installation, and a strut mount rebuild in the first video:
https://youtu.be/BAcgxcbAH3Y
and the second, I install the braces I made to fit behind the door panels under the rear windows, and test the flex in the shell. Results in the video!
https://youtu.be/2KpM24csMQw
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
https://youtu.be/dAgZw1i9qqc
https://www.youtube.com/watch?v=H5JdlCi9Xc4
https://www.youtube.com/watch?v=ne4mgcPLLKQ
https://www.youtube.com/watch?v=UDBFrEuPFBE
Did up some custom Gulf livery Recaros for the car, changed out the engine for a CZTA 1.4t from a 2016 jetta, and have been working on the paint and getting the doors painted to match the rest of the car. Taking it to the first event it's been to here in a few weeks. I've been distracted with a few other projects in the meantime, including a 928 and another datsun roadster.
https://www.youtube.com/watch?v=GD3JLU-iRtQ
