1980 MK1 Cab "ALF"
(In Topic #183651)
My long term plans are to go for a full restoration, but in the mean time while funds dictate I will just be focusing on a few areas. I also need help in indentifying the engine this car has in it, this is my first project and I am still new to the mechanics of vehicles! Looks like the forum will be a great source of info, also keen to get chatting with other Mk1 Owners in the Bristol/ South Gloucs/ North Somerset area, Pics attached.
Max
One thing I noticed in your photos, your accelerator cable where it clips into the rocker cover, it should be clipped through the recess in the rubber, and not as far up the cable as yours is clipped in. If this makes the cable too tight, you should be able to unscrew the adjuster to make it correct.
1983 White cabriolet GTi
Maniac said
Looks like a great base for a project, a little tired but straight. It's an early cabriolet as well at 1980, pretty much as early as they get.
Just noticed that, I will get that sorted. Hoping somebody will be able to tell me which engine this is, I was told it is a 1.8DX on another forum Sourced a new passenger side door in black as this one has a couple of bits of deep rust, especially behind the handle, where it is quite rotten! New door has zero corrosion.
I think for your year of car it should be a 1.6 injection but could be wrong.
Easy way to tell is water pipe on 1.8 enters cylinder head between cylinders 3 and 4, on the 1.6 it's between 1 and 2
Hairyarse said
Yep engine is 1.8DX with K-Jet injection.
Thanks for the tip Hairy. Id really like to do an overhaul/rebuild of the engine and get it painted up, get the bay nice and clean at the same time. How difficult is this? I am someone with a good understanding of how things work (love engineering!)
But no experience putting it into practice!
1992 clipper…….. "THE BLACK ONE"
1990 mk1 caddy…… " THE PIKEY WAGON"
1969 type 3 notchback
If head needs a refurb for the money I'd be inclined to get someone like TSR to do it, fair money and peace of mind. Then get a full seal/gasket kit and just start stripping, cleaning, replacing, rebuilding.
Unless you know the bottom end is knackered i wouldn't bother stripping it, they can be good for 250k miles if well maintained before needing work
Max
change that rear golfgti badge for the proper early one as well
Hello Max
I think your engineering skill comment above will cover a lot of people on this forum, definately me
Just take it at your own pace and enjoy it. Theres a wealth of useful people and info on this website
Matt
Had a mad moment earlier in the month and nearly sold the cab, but didnt want such an old one to go and someone who doesnt bleed VW end up ruining it
So anyway, Alf went in for his MOT today, two new shocks rear needed (which I kinda expected anyway as they are a bit bouncy) New brake pipe bracket which had rusted off, Battery tray bracket as it wasnt secure enough, and a couple of new fuses and bulbs thats it!
Bloke even went as far to say how impressed with the bodywork he was, and how little corrosion it has, convinced me to hold on and see the project through even more! Highly recommend Gordano Motor Services near bristol, VAG Specialists been going about 50 years!
Anyway, will have a little think about what to do next and post later! If anyone has an interior for sale that would suit black, please let me know!! also after a cigarette ash tray/lighter and a period radio if poss!
Being new to restoring cars just been hunting tools on ebay, managed to get a 40 piece snap on socket set for £32 used but great nick!
Regards Volkswarren
volkswarren said
is it on a private plate? or is it a V Reg?
No it is indeed a V Reg, I havent seen one this age anywhere been looking for another similar. Original roof still aswell!
Regards Volkswarren
volkswarren said
i owned MVS193V it was on ebay a few months back but the guy broke it as no takers, mine was a series one cabby though, didn't think you could get series two on a V Plate
Is there a way to tell? Its had a lot changed in its life I think…….
Its registered as a 1980 1588cc GLI on the V5
