83 Gti set to get full resto
Sure will, cheers Richie
borednow said
Awesome work Andy. Must be nearly finished now. What the hell are you going to do with all your spare time when it's done?
Ian
Yeah, nearly there Ian. I'm looking for another one Got bigger plans tho
Fancy a drive down to "just past" the midlands for a day out and a break from your golf… Hot teas a plenty? I'll be you best friend lol
Wanted: Front Bumper, DESPERATELY NEED A DRIVERS WING!
MY Build Thread
My Facebook Build Page #Project83
Nice try, the tea is really tempting What's up like Alfie?
Fantastic work on the A-pillar Andy. Mine has rust in that spot too, I'm hoping thought it's only on the outside and not so bad but I'm not counting on it!
When's the big day for it going in the body shop?
Melteddrummer said
Ian
Oh yeah! Sounds intriguing? Hmmm do I smell a space frame racer on the cards?
Ian
That's how mine started mate, just a small hole. It's not that difficult a job once you know how it's all put together.Hairyarse said
Fantastic work on the A-pillar Andy. Mine has rust in that spot too, I'm hoping thought it's only on the outside and not so bad but I'm not counting on it! When's the big day for it going in the body shop?
Was supposed to be going to the body shop mid next week but the body shop are delayed with a 'Hot Rod' they are doing, by 5-6 weeks cf_emoticons__BangHead:I'm just going to spend this time trial fitting the engine, FMIC, arch spats etc, just so all the holes etc are drilled before paint
borednow said
Melteddrummer said
Ian
Ian
Your work on the 'A Pillar' has left me speechless!
Cheers, Mike, much appreciated
Oh shame on the delay - at least it gives you time to check, re-check and fettle!!
Very small update.
Things have been very quiet down the unit the past few weeks as the bodywork is pretty much done now. I did find one other thing to fix though, which is a latch for one of the door check straps, which had snapped off at some point.
I think it must have had a shunt at some time.
in
out
Something has definitely happened here before as it was all split, so chopped a square out to investigate.
Cleaned up and weld thru primer applied
New patch
Forgot to get a pic of the latch welded in as I closed it back before I remembered
Etch primered
I also unearthed my 1.8T ready to be fitted before the shell goes off to the painters
I've basically got three weeks to trial fit this engine as I'm off to Goa on the 20th November for a wedding and when I get back the shells going off to the painters. So not much time
That's it for now peeps.
in
out
New patch
Etch primered
Nice work Andy, have you got all the mounts ready to go?
Yeah got all the mounts, just need to fit a bush in one of them, this is why I wan't to trial fit now, so I can get the bush in the correct position inside the mount.
Need to fit FMIC as well
Yeah staying Mars Red, it's the fastest colour after all!!
More top work andy! And almost paint time
What are your plans for the engine?
1.8T with K04 turbo and 02A Gearbox, going to be running standard ECU. Just been down to try the 02A gearbox on the engine and it don't fit Not sur if I'm missing something but there's more holes on the engine than there is on the gearbox
Here's a couple of pics to show what I mean
Any Ideas anyone?
