Wanted engine bay wiring loom ecu tci loom for 16v kr plus ecu and tci mk1 8v gearbox 100mm driveshafts for conversion
(In Topic #153604)
16v wiring loom and ecu/tci gearbox driveshafts
Hi i need the engine bay wiring loom for the ecu/tci from a 16v kr to splice to my 8v loom on my mk1 conversion
Also the ecu and tci if available
also a mk1 8v gearbox ive got the mk2 16v but havent got 100mm drive shafts or 100mm driveshafts if anybodys got some
Any help would be greatly appreciated
No splicing involve fella, take the power to the ecu from the coil, a wire goes to hall sender, earth, water temp, earth to head I believe and 2 to the coil. If I remember rightly.
I have the said "Kr ignition loom" spare, and your engine loom will be fine unless you want a full ce1 16v loom as some do?
Hi thanks for that as simple as possible is how i like it
let me know what you want for the loom
thanks again
guy
thanks again
guy
Pm me re the spit and this do a deal.
I have kr ecu
I've got loom, ecu, tci module and a genuine Bosch dizzy btw.
