some newbie questions!
(In Topic #102191)
where can i get body moulding trim clips from??
how much work is involved in replacing a front wing?
where are the common points for the cabs to leak from??! seems to be coming from somewhere
cheers all 8)
You can get trim clips from VW they cost penny's.
Dont know about replacing front wing have never done it but my cabby leaks at the front above the windscreen. if you spray it with a hoes you will soon see where the water is coming in. You can probably solve it once you where the leak is.
Yorkshire Region Host
Mk1 Cabriolet 1500 (under resto)
Mk1 GTI
Mk1 GTI
