Okay I'm a lil stupid!!
(In Topic #107391)
God bless rich he got a repair rather than a replacement kit on the way as I didn't fancy payin the p&p!! But can any1 tell me good ways to improve the acceleration as I was mortified after I got a lil creamed by a 07 gti the other day!!
Plus I can never let it go down past a half tank of petrol as it shakes, shudders, battery light flashes and some times cuts out, and very rarely won't start again, usually when I facing up hill. Mechanic said he looked inside tank and could't see any dirt, unbelievebly clean for car thet age, fuel pick up clear, have had 2 new fuel pumps to no avail!! Other than she sweet as
Now ye might hate me for sayin this but I want a new car as Gretta(my clipper) is my daily driver at mo and I just need to give her a break to get her sorted out proper, and I hate seein the mileage clock spinnin round as I doin 500mls+ a week!! Going to look at a mk3 vr6 tomorrow? Any feelings on these? :dontknow: :dontknow:
Sorry to hear you're having problems. I would post up some threads about each query in the relevant sections if I were you (big block carb engines, fuel systems etc) that way you might get a better response from knowledgeable folk who might not visit the 'new folks' section.
500 miles a week is a lot for any car! It's a popular view that the Mk3 Golf VR6 is the only Mk3 worth having! :wink: As long as you get a good one, the youngest Mk3's are now nearly 15 years old 8O.
As for getting creamed by a Mk5 GTI, I wouldn't worry about it, even if you were in a GTI instead of a carb you'd have trouble because the most recent GTI models (Mk5+) have well and truly caught up in terms of 0-60 times and power-to-weight ratios!
as for advice you have come the the right place but as diesel-dubber has said why not post up a thread for each different issue and then people can help you one by one.
:cheer: I've got my husband back :cheer:
Member 125 - 2005
also sounds like it, as you mentioned it happens when its faced uphill.
Get the carb kit fitted, that may improve things, see where you go
from there, ps you only need a tiny amount of dirt in the tank to
make it start spluttering, so dont rule it out, check the filler neck
(where you put petrol in) and re check the tank after its settled
for a while, any sediment will be at the bottom of the tank then.
Mine did the same thing a couple of years ago, (mine was injection though), but the same symptoms.
Best of luck
Dibbler
