(In Topic #113485)
I have just helped my sister buy a clipper and i need some advice on where to get parts.
The car is a 1988 karmann clipper with only about 60K genuine miles on the clock. The carb has been changed to a webber unit although not sure which one.
The body is pretty much mint no rust just a couple of car park dings.
The first thing to do is replace the fuel filler pipe as its rusted. Where is best to get one and is there an aftermarket plastic option?
Thanks in advance
mark
It dunt fit
another tech question does changing from the perburg to webber carb actually do anything for the proformance or is it soley reliability?
Also are the 1.8 carb engines overhead cam and do they use hydrolic lifters?
You will have to bear with me if these questions have been asked before i know nothing about golfs.
Glad to have you as one of our users (new to golfs or not ) :y:
As for the weber to replace pierberg, if it aint broken dont fix it.
And before changing carb there are other bits to check first.
But as mentioned already technical sections will get you the best advice which I see you have done.
1988 1.8 carb Golf Clipper
