Newbie from SA
(In Topic #120586)
Newbie from SA
Ziyaad here from sunny South Africa….
I have an 82 MK1 GLS 1.5 and busy restoring to it's original glory
Would be great to see some photos!
from S A on here, not sure of the user names though?.
Would be good to see some pics!
Dib.
just need to take some decent pics when I get the car back from the mechy busy overhauling the motor
You'll find plenty of info and help on here to assist you with your resto if you need it
Chris
I no longer have the Mk1!! I now whizz round in a Black 1990 3dr Mk2 GTi 8v but the roof doesn't fold back when the sun shines
Where you from
got her back from the macky reconed the motor still running 1.5 but with a twist newer model (2008) 1.4 carb head (better flow and gives better compression ratio) ff box but am thinking of changing it as the motor itself doesn't have enough power for the long ratios. will probably in time change over to a FFZ or DGG box as I think it will work better for the motor. have branch and free flow which also helps a bit on the performance side
the car has the following:
- 40mm drop shortened springs no coils
- motor was done
- 16" steels narrow and wides for the bakgat stance
- Michillen (not sure on spelling) 195/45 16 for the stretched look
- chrome Audi door handles
s/a car
here in SA we had a breakfast run where the pic was taken the tail behind me is the okes partaking in the run
