New Boy Needs Advice
(In Topic #94082)
I will get the bodywork sorted and resprayed,and will have ?1000 for the engine,what sort of power could i achieve with that amount of cash.I have a seperate budget in mind for the exhaust etc..
Life Member
Off top of head, but don't quote me on it:
Engine
CLutch/flywheel
All the inlet manifold, induction system, inc metering head
wiring loom for ignition, including its ECU
You have to swing across the fuel lines from one side of the car to another, and clip them on into their new location. Also you have to relocate the washer bottle. Clutch is done by using the 16V pressure plate and 8V friction disc, feeding into the original gearbox (tho many people have swapped for a Mk2 gearbox with 100mm flanges. If you go for the 16V box, you need to match the friction disc too, since it has a 24mm input shaft compared to the others' 22mm).
I ended up replacing a lot of parts too - radiator, upgraded oil coolers, engine mounts, igintion ECU, coil, starter motor, etc which really added to the costs. Also I had a lot of the stuff powder coated, and rebuilt the top end of the engine.
There's a FAQ somewhere - PM ManicGTI who maintains it, he can email it to you.
Life Member
A5OPY said
just like i said
