Mk1 Golf 1.5 5 Speed
(In Topic #76601)
What im after is a few things to look out for i.e places for common rust, the car already ahs 12 months MOT on it but i just want to make sure she will last a few more years.
And if anyone knows of any common engine problems with the 1.5 id be most greatful, will be viewing car next week
cheers tim
edges of front panel where the wings meet
top edge of inner wings
below the windscreen
sills
rear arches (GTIs worse because of the plasstic spats) inner and outer
rear axle mounting points
filler neck area
rear seat belt mounts
spare wheel well
lower section of the rear panel
screw holes for rear license plate
oh, and if there's a sunroof.. around that and the drain holes
check around the lower edge of the doors and rear hatch too and have seen rust around the rear quarter windows too
think that covers all the areas of possible rust
CAN ANYONE POINT ME IN THE RIGHT DIRECTION WITH ANY COMMON ENGINE PROBS THE 1.5 HAS IM ASSUMING IT A CARB ENGINE
I'm not saying that they all do this but when you view ask if you can see the car started from cold (feel the engine 1st to ensure it is cold!) and after test drive when at normal temp, try a hot start and make sure this is ok and idle.
Idle when warm should be around 850-900 rpm mark.
Re the model, I'd guess it's a GL but just check the badge on the back!
Good luck and keep us posted.
ILL GO HAVE A CLOSER LOOK NEXT WEEK AND LET YOU KNOW HOW IT IS RUST AND ENGINE WISE
CHEERS TIM
PS: CAPS LOCK MEANS YOU'RE SHOUTING!!! (Or I guess you could just be VERY happy!!)
