Leaky Golf
(In Topic #72530)
Leaky Golf
I've recently purchased a mint A reg Golf GTI that has developed a nasty habit of saturating the footwell carpets front and rear. Is this a common fault? The floorpan seems fine. I'm wondering whether to take the carpets oot to see if I can track a leak from the bulkhead area.
Any advice will be greatly appreciated.
Jas
theres a post in Chat I think Filemouse talking of this problem. Might be worth you looking there as it talks of the common problems to look for..
In torrential rain, especially if the drain holes at the bottom of the door are blocked, and the plastic door membrane is not 100%, then water can drip past the bottom of the door card onto the sill area inside the car and soak the rear footwell this way.
Pull the door cards off and have a poke around inside the door s to see if things are wet.
Also does the car get particularly wet if parked facing up or downhill? If the boot mat is getting wet and the car is parked facing downhill then your rear light seals might need replacing.
Cheers,
Chris
Plus, as Chris says, remove the door cards. It's surprising how much water can come through a tiny hole in the membrane, but it's an easy fix.
I used a combination of windscreen silicone sealer from Halfords with sections of plastic sack from coal bags cut to size! (and cleaned first of course!)
Leaky Golfer
thanks for the info regarding leak causes. I'll ckeck the door card soon as it's due a wax oil.
I've had a prod of drain holes under the bonnet but it did seem to be ok, however whilst poking out the sunroof drain holes the drivers side pipe was not connected to the drain hole so that's sorted now.
I've also noticed that the pipe on the passanger side sticks out by the door hinges but on the drivers side has fallen into the cavity by the hinges. Is this a problem? I've tried to coax it out but the bugger has the better of me!
Enjoy!
Jas
